Thermostat location
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
DANIELUSALAZAR
How to replace the thermostat, and where is located it?
Oct 11, 2009 at 4:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The thermostat is located near the bottom radiator hose. Here is a guide to help you see step by step and diagram below to show you the locations:
Cheers
Oct 11, 2009 at 3:49 PM
ROD GALE
Where is the thermostat located? I cannot seem to find it.
Aug 2, 2018 at 10:51 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
See a pipe coming off back of water pump? At the end of pipe see two bolts that is thermo housing. Remove and there is thermostat.
