Location of Idle Air Control
71,000 MILES • 4 CYL • 2WD • AUTOMATIC
ELBANANO
Hi i Have a Problem With RPM Needle And Want To Clean Out the IAC But Can Not Find it. The Haynes repair manual doesn't mention it. Where is its location and how do i clean it?
May 16, 2010 at 3:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
This car does not have an IAC motor because it is drive by wire. You should service the throttle body which can take care of the problem this guide will help
May 16, 2010 at 4:40 PM
ELBANANO
Thank you the guide worked like a charm! this site rocks water back.
May 16, 2010 at 4:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
May 16, 2010 at 4:46 PM
