I'd need the actual codes to help you.
Also, when the computer sets a code, it isn't saying that those specific components need to be replaced. It's only pointing you in a direction to begin you troubleshooting.
And there's more than one kind of "Misfire". This can also be a "Lean misfire", which is your fuel system. This would usually be a clogged injector.
Get back with me on the codes and I'll help you from there.
SPONSORED LINKS
Wednesday, March 3rd, 2010 AT 7:23 PM
