2005 Chevy Cobalt Check Engine Light
90,000 MILES • 4 CYL • FWD • AUTOMATIC
KARBBY
I have a 2005 Chevrolet Cobalt base model. My car randomly dings and says "power steering" on the lcd screen (I've already had my power steering replaced under recall). When that happens my car shifts hard and my check engine light comes on. When I read it the following codes showed up;
u0073 Control Module Communication Bus Off
po171 System Too Lean (Bank 1)
Fuel Trim System Lean
po700 Trans control system malfunction
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position
Performance
So now I need to know how to fix it. :/
Sep 30, 2010 at 5:13 AM
MMPRINCE4000
  • 8,548 POSTS
The "U" code indicates the PCM is not comunicating with other modules.
This would have to be checked with high end scanner and may be cause of other codes.
This is dealer/trusted garage job as these scanners cost in excess of $10,000.
Oct 18, 2010 at 2:00 AM
