2005 Chevy Cobalt Car shakes after hitting 50MPH
65,000 MILES • 4 CYL • FWD • AUTOMATIC
LETHELDOCE
The car used to shake when on the highway, but before inspection I put new tires and brakes on, and the shaking stopped. (in Feb 2009) I havent really put that many miles on the car since, and it started shaking again. You can hear the shaking in the stearing wheel when driving. I don't know what would cause it to start again after it seemed to be the tires that was the problem last time.
Aug 31, 2009 at 7:04 AM
MMPRINCE4000
  • 8,548 POSTS
Have the car aligned. It may be out of alignment (toe, camber), or a steering component is worn (ball joint, tie rod, control arm. bearing, bushing).
Sep 7, 2009 at 1:06 AM
JOEFIXACAR
I had the same issue and it was the rotors and check for anything like stones by the CV boots. i hope this helps.
Nov 24, 2009 at 3:56 AM
