1982 Chevy Citation wiper arm assembly replacement
JEVEREB
1982 Chevy Citation
how to remove wiper arm and put on new arm assembly
Jun 3, 2010 at 8:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Removal of the wiper arms requires the use of a special tool, G.M. J-8966, or the equivalent. Versions of this tool are generally available in auto parts stores. Insert the tool under the wiper arm and lever the arm off the shaft. Detach the washer hose from the arm. Remove the arm. Installation is the reverse. The proper park position for the arms is with the blades approximately 2 inches (50 mm) above the lower molding of the windshield. Be sure the motor is in the park position before installing the arms.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c15280083e24_1.jpg
Jun 3, 2010 at 8:02 AM
