1981 Chevy Citation Master Cylinder
1981 CHEVROLET CITATION
138,450 MILES • 4 CYL • FWD • AUTOMATIC
DCGREEN
I'm having trouble removing the rear brake lines from the master cylinder. I have applied penetrating oil but nothing good has happened yet (the nut started to round over). The master cylinder appears to be made of aluminum while the nuts on the brake lines appear to be made of steel. Can I apply heat to these connections and if so to which component? Is there a way to recondition the flare nut or do I need to cut it off and splice in a new connection?
Nov 27, 2009 at 7:40 AM
Hi dcgreen and TY for the donation
Grab it with a vicegrip and splice in a new connection or replace the brake line. Once its round off its a done deal
Nov 27, 2009 at 8:11 AM
DCGREEN
There are two flare connections going to the rear brakes. One flare nut is still good. This is the one I asked about the heat. The one that started to round in still gripable but needs some kind of lub of how do I correctly apply heat to this connection as well?
Nov 27, 2009 at 8:18 AM
Shoot it with penetrating oil and use a blow torch
Nov 27, 2009 at 8:21 AM
