Replacing the high pressure power steering line.
A. PARKER BEDINGFIELD
I own a 1992 Chev Cheyenne that has 197,000 miles on it with a 350 V-8 engine, 2 wheel drive and standard transmission. Recently I tried to replace this line but was unable to turn the nut where the line connects to the steering shaft without possibly damaging the nut. Any suggestions?
Oct 24, 2007 at 9:58 PM
2CARPRO JACK
  • 11,533 POSTS
Are you using a flare nut wrench? If that wont work, try cutting the hard line off so that you can slip a 6-point socket over the nut
Oct 25, 2007 at 11:47 AM
