1999 Chevy Cheyenne Engine wont crank
97,000 MILES • V8 • 2WD • AUTOMATIC
COREY BURFORD
I have placed a Diognastic computer to the truck and replaced all parts associated with issues. engine cranks but will not turn over, but will start immediatly if starter fluid is used. the only remaining code in the computer is mass air flow senser input high.
Mar 2, 2008 at 2:22 PM
  • 75,988 POSTS
You have a fuel issue-check the fuel pressure and report back you findings-BTW when key is at run position-do you hear the fuel pump.
Mar 2, 2008 at 2:30 PM
COREY BURFORD
we had the fuel pressure checked at that time it was good, the fuel pump runs when the key is turned. im at a total loss. all plugs are firing properly i replaced the ignition module and the EGR valve
Mar 2, 2008 at 2:53 PM
  • 75,988 POSTS
Check engine compression/valve and ignition timing.
What was the fuel pressure when you checked it?
Mar 2, 2008 at 4:12 PM
