1998 Chevy Cheyenne replacing drivers door handle
68,520 MILES • 6 CYL • 2WD • MANUAL
BSTRICKLAND
is there a place that I can get info on taking the door panel off and on. What tools that I am going to need. do I need to buy new clips to put the panel back on. Have the window handle off that was pretty easy, got the new handle to open just need more info before I start this project. Thank You
Mar 14, 2008 at 7:39 AM
RHALL77
  • 3,361 POSTS
some of those panels lift straight up on GM. make sure you dont pull straight out and damage it. Remove all screws, mark where they go. Pry the door panel out a little and see if you can see in there. You will be able to tell if the door should be lifted straight up or not.
Mar 14, 2008 at 7:52 AM
BSTRICKLAND
thank you for your reply. Will I need to get new clips to put the door panel back on or will I be able to use the old ones?
Mar 14, 2008 at 10:03 AM
