1998 Chevy Cheyenne no fireing
176,000 MILES • V8 • 2WD • AUTOMATIC
SJBMK4
i was setting in a drive thru in truck and it shut off tried to crank back up but it wouldnt i have pressure at fuel rail and pulled valve cover off to make sure rocker arms were still moveing and they were i checked coil for fire and did not have any so i replaced the coil and i still am not getting any fire out of top of coil what fires the coil and what is my prob
Oct 29, 2009 at 2:45 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 30, 2009 at 2:41 AM
