Engine Mechanical problem
1998 Chevy Cheyenne 6 cyl Two Wheel Drive Automatic
have a 1998 chevy 1500 pu that just "shut down" on me while driving. It appears to be getting a spark but wont start. I ruled out the fule pump as I can hear it when I try to start the truck, I replaced the fuel pump relay, I recently replaced the fuel filter, disconnected the line past the filter going to the engine and there was gas in the line, so it appears to be going through the filter, I checked the "valve" behind the injectors to see if gas was getting to the injectors, very little squirted out when it should be 60-66 psi ( or so my manual indicated). I am at whits end!
Jun 30, 2010 at 6:29 AM
