1998 Chevy Cheyenne just died chevy truck
1998 CHEVROLET CHEYENNE
250,000 MILES • V8 • 2WD • AUTOMATIC
FATFAT8
  • 10 POSTS
truck was ok had a stalling problem but i think that was with the fuel ( a small vacumme leak it runs on propane )
rotor and cap are fine just changed a few weeks ago
also changed the coil and the modual ( I read another guy with the same problem)
number one plug lines up with crank shaft marks so timming belt should be ok
give it a shot
Aug 1, 2009 at 8:33 AM
2CARPRO JACK
  • 11,533 POSTS
Does it have spark? Im new to propane so were gonna start basic.
Aug 3, 2009 at 1:39 PM
FATFAT8
  • 10 POSTS
no sp[ark from plugs
has 12 volts going to coil one side nothing other side
Aug 3, 2009 at 8:00 PM
2CARPRO JACK
  • 11,533 POSTS
Have the PCM scanned for codes,it may have a bad cam or crank angle sensor so the PCM cant see the engine turning
Aug 4, 2009 at 3:17 AM
FATFAT8
  • 10 POSTS
a mechanic told me that the timming belt slipped
but the crank shaft marks and the roter line up at number one top
I through ever if the timming was a little off the engin would start roough but start.
Aug 5, 2009 at 6:15 AM
2CARPRO JACK
  • 11,533 POSTS
It doesnt have a belt, its a chain.Line up #1 piston to TDC, then remove the dist cap and see where the rotor is pointing.Look at the inside of the cap to see where the contact is, the plug wire goes on in a different place than where the actual contact is inside the cap, if it is off, then it may very well have skipped the chain.Did you try scanning the PCM?
Aug 5, 2009 at 7:01 AM
FATFAT8
  • 10 POSTS
The rotor seems to be a the number one when the cramk is on the mark, even if it was a little offf it should start but rough
I got a code reader and checked there are no codes
not sure what the pcm is ?
checked the crank shaft sensor supposed to be 5 volts ac only getting .3 or so could it be that
Aug 26, 2009 at 6:11 AM
2CARPRO JACK
  • 11,533 POSTS
Shoul;d be 3 wires at htecrank sensor, ground, 5 volts and the last is signal back to thePCM (computer) if you dont have 5 volts at the one of the wires that is most likely the problem
Aug 26, 2009 at 7:46 AM
FATFAT8
  • 10 POSTS
we tested the yelow wire what the book said
book also said that if the sensor was bad there would be no spark
it seems kind of simple do they go bad ?
Slao what about the cam sensor could that be the problem
Aug 26, 2009 at 8:03 AM
FATFAT8
  • 10 POSTS
one more note
the truck was stalling when comming to a stop
when you take your foot off the gas it wold cut out
and it was getting worse
Aug 26, 2009 at 8:09 AM
2CARPRO JACK
  • 11,533 POSTS
Yes they do go bad, and I have replaced many of them.The cam sensor could also be the culprit, but they dont seem to go bad as often as the crank sensors
Aug 26, 2009 at 8:38 AM
FATFAT8
  • 10 POSTS
that was it
when testing the old one we cleaned it off and the truck started
volts a/c were only 2
new one 4.7 stillnot five maybe dirt ont he connections
Would cranking the engin without the sensor being in change the timming ???? the guys were running the test and it was not in.
runs rough and backfires the code said corralation was off. The book siad to erase it so I did
Aug 27, 2009 at 3:51 AM
2CARPRO JACK
  • 11,533 POSTS
it will set that code if you crank it with the sensor out or if you moved the distributor.
Aug 27, 2009 at 5:15 AM
FATFAT8
  • 10 POSTS
changed the crank sensor the truck ran great
next day test drive after about five minutes shut off again
sensor voltage was at 2 than 4.7 but not starting
Whats the Problem It has to be something
simple we re not seeing
Sep 3, 2009 at 1:44 AM
FATFAT8
  • 10 POSTS
truck was stalling on and off
truck stopped starting
distubuter and rotor looks ok number on rotor and crank shaft markings ok
no spark
changed coil
changed ignition moduel
no spark
crank sensor putting out 2v a/c getting 12 v dc
code reader found no codes
changed crank sensor started right up
drove around five minutes and stalled
truck tried to start but kept diying out
Hummmmmmmmm has to be a simple problem
my friend said theres a pick up coil in the distrubter u could not find one.
Is the moduel bad.............
thanks
Sep 5, 2009 at 6:21 PM
2CARPRO JACK
  • 11,533 POSTS
It could be the cam sensor, but that will ususally spit out a code, or at least let the engine run, just poorly.You may have a wiring problem betweem the computer and the crank sensor.Try hooking up your meter and see if the voltage varies if you move the wiring harness anywhere, this is an indicator of a bad wire.Also check every connector for pin-backout and corrosion.Also check continuity to ground through the sensors connector to see if th econnector itself may be bad
Sep 8, 2009 at 12:44 AM
FATFAT8
  • 10 POSTS
we checked allthe connectors ran a olvtage test and shoke the wires nothing
could the computor by bad PCM theres no codes
we have a chevy blazed whee it was going bad about the same miles 240000
I keep thinking something we are missing
Sep 11, 2009 at 5:31 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the PCM if all wires and connections are good, since the voltage is varying.
Sep 14, 2009 at 12:31 AM
