Ineed to change the flywheel on this truck and I need some help?
Jun 7, 2009 at 2:33 PM
PEAR69
✓Experienced Mechanic
Its pretty simple. Remove the front and rear drive shaft - transfer case - starter - transmission along with the torque converter - and then the fly wheel. Install is the reverse. Besure to properly torque the fly wheel using a criss cross pattern and three steps.
