1998 Chevy Cheyenne cold start performance
183,000 MILES • V8 • 2WD • AUTOMATIC
RPISHA
Slow to start. OK after several attempts. fuel filter is new. Spark plugs are new. Runs well once started. Fuel pump/sending unit was replaced but I have noticed that fuel guage sometimes "twitches". Do fuel injectors have their own "high pressure" pump or distributer on engine? What about a fuel pressure regulator? It runs good but it should start easier. THANKS ! for any ideas..
May 9, 2010 at 6:40 AM
  • 75,988 POSTS
Hi rpisha, welcome to 2carpros and TY for the donation.
Check the fuel pressure with a fuel pressure gauge to rule out a failing fuel pump and also test the coolant temperature sensor and also fuel pump relay
May 9, 2010 at 4:23 PM
