My 1997 K2500 with the 7.4 liter engine when starting will sometimes start normally, sometimes crank but not start and when this happens the warning lights do not light on the dash and the voltage guage shows no movement then suddenly the gauge/warning lights will light and the voltage gauge shows voltage and the engins starts normally. Lately, it's taking several attempts to start and the newest issue is that the starter won't engage as if there's no power to the starter...then once again, after several tries, the engine starts normally and all gauges and warning lights are functioning normally. I'm concerned that the starting issues seem to be getting worse over time and the attempts needed to start the engine are increasing...Could this be a bad ignition switch that is gradually failing or has corroded and needs to be replaced....
Thanks for your help.
Jan 10, 2010 at 2:00 AM
