1997 Chevy Cheyenne Fuel delivery
1997 CHEVROLET CHEYENNE
125,326 MILES • 6 CYL • 2WD • AUTOMATIC
NAVARRETE068
  • 6 POSTS
Engine: 4.3 Vortec 6cyl
why dont I get power to the fuel pump?
Is there a fuse that Im Not Finding?
Ive changed the fuel pump relay and the fuel pump.
I can get the pump to work if I jump the power line
into the pump ( The Grey/White wire).
HAYNES Manual dosnt specify this motor.
Feb 14, 2009 at 2:17 AM
JDL
  • 16,098 POSTS
Did you check the ecm B fuse in the underhood electrical center. I believe that fuse circuit goes hot when you turn the key on. Also there shows to be an oil pressure switch in the fuel pump circuit, once you crank it enough to bring up oil pressure, the pump should run, there should be pressure. That doesn't mean the injectors will pulse.
Feb 14, 2009 at 2:28 AM
NAVARRETE068
  • 6 POSTS
Where is the ecm b fuse located
ive checkd the wiring from the pump to the fuse box.
Feb 21, 2009 at 9:05 AM
JDL
  • 16,098 POSTS
The info I looked at was for a 97 1500, owners manual. Look in the under-hood fuse box or relay center, driver side rear, close to the brake fluid reservoir. It's possible that is a relay pack instead of a box.
Feb 22, 2009 at 2:32 AM
