1997 Chevy Cheyenne Bearing problem
19,200 MILES • V8 • 4WD • AUTOMATIC
CARPENTERS
The left front tire, while driving makes a grinding sound, I replaced the break pads, and it's not the 4x4 gears. Also when the truck is jacked up, I can move the tire up and down with lots of play. side to side movement is tight. help
Feb 5, 2008 at 9:19 AM
2CARPRO JACK
  • 11,533 POSTS
Needs a new bearing (hub). Not too hard of a job.A little further than the brakes, but not too bad.Might want to go ahead and do both sides at that mileage.
Feb 5, 2008 at 11:58 PM
