1997 Chevy Cheyenne 97 Checy truck wont kick over
134,354 MILES • 6 CYL • 2WD • AUTOMATIC
NAVARRETE068
  • 6 POSTS
I just replaced the brake light switch. now the engine wont kick over, I checked the distributer and found that their is no spark. what would be causing that problem and how can I fix it.
thanks
Nov 3, 2009 at 6:53 AM
  • 75,988 POSTS
I just replaced the brake light switch. now the engine wont kick over-you probably loosen a wiring connector while you replaced the brake switch check it-if not-do below
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Nov 3, 2009 at 7:06 AM
DOCFIXIT
  • 18,828 POSTS
So car was starting before you replaced brake switch?
NAVARRETE068
  • 6 POSTS
the engine was running fine b 4 I changed the brake light switch. I checkd the distributor and theres no blue spark.
Nov 3, 2009 at 8:26 AM
NAVARRETE068
  • 6 POSTS
Is it possible I disconnected something relating to the starter that would be next to the brake switch?
Nov 4, 2009 at 1:34 AM
DOCFIXIT
  • 18,828 POSTS
See if fuse #18 is blown in I/P fuse box
Nov 4, 2009 at 6:32 AM
