1996 Chevy Cheyenne Truck won't turn over
17,500 MILES • 6 CYL • 2WD • AUTOMATIC
KNOW
Relay is good, battery good, starter and solenoid good.
What the H&++. I've tested the wires between, power at both ends. straight wired the starter it works. Make all connections, turn the key------NOTHING. i ALSO TESTED THE NEUTRAL SAFETY SWITCH---GOOD.
Is there something else I am forgetting?
May 3, 2008 at 8:45 AM
  • 75,988 POSTS
The purple wire at the NSS does it have power when key at cranking position if so test out the starter relay power has to come out from it -to get to the starter solenoid. Or jump the 2 purple wire at the relay and attempt to crank.
May 3, 2008 at 9:18 AM
