1996 Chevy Cheyenne stalling out when driving
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEROY710
my truck will stall out while driving without bogging down or any sign will cut out not ecltrical pull over and starts right back up fuel pump sounds like a fan running while sitting in park
May 19, 2010 at 3:01 PM
02REDCAMARO
  • 65 POSTS
I had a '96 once with the same problem. My problem was a single wire that came from the ignition coil. It had rubbed/chaffed on something and the connection was almost completely gone. It should be a black wire. I just spliced it back together and used plenty of shrink wrap tubing to protect the wire better. Whatever your problem is, it sounds like ignition. You also might want to check your distributor cap and rotor for cracks or wear.
Jul 10, 2010 at 11:39 AM
