1995 Chevy Cheyenne Truck will still not go in to gear
1995 CHEVROLET CHEYENNE
115,000 MILES • V8 • 2WD • MANUAL
CHRISKUBECZKA
We replaced clutch with a clutch kit. Also replaced clutch fork and clutch fork ball stud along with clutch master cylinder and slave cylinder. The system has been bled a couple of times it still grinds into reverse and will not going into gear smooth. We are at a stand still on what could be done. Please hepl!
Aug 11, 2008 at 12:01 PM
VGABND_210
im having a very similar problem...please let me know when you get an answer...have you checked the throw out bearing and spindle?...also..if you put a newer clutch in you need a different fork than factory spec.
Feb 7, 2009 at 8:24 PM
