I was plowing snow with my truck for ~1/2 hour, when the Brake system warning light came on, and the 4wheel drive (4WD) stopped working. The light went off after about 10 minutes, and 4 wheel drive resumed working. The transmission fluid level appeared normal. Next day I started truck and Brake system warning light stayed on for about 1/2 hour! During this time 4WD did not work. Then light went out and 4WD resumed working. I haven't started it since. Do you know what the problem is? Thank you very much. Roger
Dec 27, 2008 at 1:02 PM
