1993 Chevy Cheyenne hood cable
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICHARD2508
the cable has come loose at the latch; how can i open the hood to replace the cable...
Dec 26, 2008 at 6:41 AM
DOITYOURESELF
  • 48 POSTS
Peek under the front of the hood where the latch is located. You may be able to loosen the latch bolts, either on the hood side or the core support side, or use a pair of pliers to pull on the cable or the cable bracket next to the latch, or screwdriver to pry the latch open. Patience will be rewarded, it can be done, and usually its pretty easy.
Jan 8, 2009 at 12:13 AM
