1992 Chevy Cheyenne JUST PADS?
ROSE1854
Brakes problem
1992 Chevy Cheyenne
I don't have alot of money to spend on the truck.
A repair shop wants $350 to do front brakes
I was told I could just get the pads put on and not
replace rotors at this time and I would have more braking power than i do now.
Is that true, can i just replace pads and do rotors later when i have some money? Thank you.
Jan 25, 2009 at 1:54 AM
BILLYMAC
  • 2,204 POSTS
hi well you can but you will have to do it yourself a brake shop can,t just replace pads. and it really depends on how bad the rotors. if they can be machined that is pretty cheap.the pads you put on will not last long. but will probably work if the rotors are good enough thanks for asking billymac
Jan 27, 2009 at 12:58 PM
