1991 Chevy Cheyenne radio
1991 CHEVROLET CHEYENNE
JITTERLOVE
1991 Chevy Cheyenne Manual
how do i reset my radio because it has a anti theft so it isn't working? i'v checked the repair manual and it doesn't tell me how to reset it. we didn't know ahead of time that we would need some kind of password before disconnecting the radio. it says that i can go to a dealer to get it reset but i would like to know how to do it myself.
Mar 23, 2010 at 2:32 AM
TOOOMANYTOYS
  • 513 POSTS
It is necessary to go to the dealer to obtain the radio code. Normally they don't charge to much because its only a number they call and enter clear code to obtain. Once they give you the code save it so if it happens again you can reset it yourself
Mar 23, 2010 at 2:45 AM
JITTERLOVE
so what if i want to bypass the radio completely and put in a new one. how would i do this?
Mar 23, 2010 at 2:49 AM
TOOOMANYTOYS
  • 513 POSTS
If you wanted to install and aftermarket radio. Remove factory radio. Then you could either buy a pigtail harness and connect it to new radio. Or you can try to wire it yourself. You would need to find the power ground and ignition source and all speaker wires cut off connector and splice each wire individually.
Mar 24, 2010 at 1:10 AM
JITTERLOVE
I want to just strip the wires. How do i find them, where do i hook them, and what colors hook to what?
Mar 24, 2010 at 3:29 AM
TOOOMANYTOYS
  • 513 POSTS
You would need to get a diagram of which wire is which and what color. I cant paste the shematic on this page it comes out to small. Most autoparts store have manuals that give you diagram.
Mar 24, 2010 at 4:36 AM
