1991 Chevy Cheyenne losing oil
20,000 MILES • V8 • 2WD • AUTOMATIC
COLINM
im losing oil from around the oil filter friends say the oil cooler lines seals one friend said i can remove it due to me not needing it as i just drive back and forth to work is it hard to remove the lines and the plate myself thank you
Dec 23, 2008 at 4:16 AM
  • 110,248 POSTS
Hi:
They can be tough. Make sure everything is tight when you change the oil next time. Also, make sure the lines are tight.
Dec 26, 2008 at 11:15 AM
