1991 Chevy Cheyenne Heater quit working
1991 CHEVROLET CHEYENNE
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEAUXTIGERS
  • 20 POSTS
The heater in my 1991 Chevy Cheyenne pickup, 4.3L engine quit working last night. I noticed the temperature gauge running hotter than normal and then noticed the heater was blowing cool air. There is no a/c in the truck, just heat. Once I turned the heater off, the temperature returned to normal. Turned it back on and had hot air for a couple of minutes and then cool air and the temperature gauge began rising again.
I guess the first place to start would be the thermostat but if it was bad woudn't I have problems without the heater being involved? Any advice is appreciated. Thanks.
Jan 2, 2008 at 9:23 AM
You're on the right track with the thermostat get that replaced and comeback for further assistance.
Jan 2, 2008 at 9:34 AM
GEAUXTIGERS
  • 20 POSTS
[quote:b88fb52321="rasmataz"]You're on the right track with the thermostat get that replaced and comeback for further assistance.[/quote:b88fb52321]
Okay, now I feel really stupid!!! I checked the radiator (should have been my first act) and I have no coolant in either the radiator or the reservoir. Don't really use the truck that often, mainly for driving back and forth to hunting camp. Admittedly, I last checked the coolant a few weeks ago.
I obviously have a coolant leak somewhere. I will fill with coolant and check for leaks.
I'm counting myself lucky it didn't overheat last night!!! No water in the oil so appears not to be any major damage.
Thanks for the help and quick response!
P.S. I will still change the thermostat - too easy to change and too cheap to ignore.
Jan 2, 2008 at 9:48 AM
Thermostat being ignored as preventive maintenance could cause serious damages a lot more than the Stat. Get it replaced and if you need more answers don't hesitate to ask we're here for you.
Good Luck
Jan 2, 2008 at 9:52 AM
