1990 Chevy Cheyenne
BFREEMYER
Engine Performance problem
1990 Chevy Cheyenne V8 Two Wheel Drive Automatic
My truck has started running rough, the fuel mileage has decreased a little, transmission shift points are not the same, it occassionally will stall while under acceleration and start again without me doing anything. I think either the throttle position sensor is bad or the MAP sensor, not sure which to try first though.
Apr 27, 2010 at 9:35 AM
  • 75,988 POSTS
When the last time you gave it a tune-up? If just recently go with the TPS and then the MAP
Apr 27, 2010 at 10:08 AM
