1984 Chevy Cheyenne
JERAMY
Transmission problem
1984 Chevy Cheyenne V8 Four Wheel Drive Manual
If the U-joint bolts have lock tight on them and the bolts are stripped out what can i use to remove them
Dec 23, 2008 at 9:33 AM
  • 110,248 POSTS
Hi:
If the bolt head is stripped, you can try to use vise grips. If you still can't get it, cut the U-bolt and replace them. Make sure you can get them at a dealer before cutting.
Dec 26, 2008 at 11:13 AM
