1979 Chevy Cheyenne parked on a hill trans fluid leaked out
1979 CHEVROLET CHEYENNE
93,000 MILES • V8 • 2WD • AUTOMATIC
CMANNN
while parked on a incline aprox. 15 min. trans fluid appeared on the ground dripping from what appeared to be where u-joint &trans.is this normal for this chevy .when moved to level dripping stopped
Sep 21, 2009 at 7:11 PM
JEEPFAN
  • 135 POSTS
sounds like you need to replace the transmission tailhousing seal. this is the seal where the driveshaft slides into the tranny
Sep 23, 2009 at 2:01 PM
CMANNN
[quote:976bad3128="jeepfan"]sounds like you need to replace the transmission tailhousing seal. this is the seal where the djeepfanriveshaft slides into the tranny[/quote:976bad3128]jeepfan thank you for timely &i believe the correct diagnosis i will replace tail housing seal thanx cman
Sep 24, 2009 at 1:59 AM
