1977 Chevy Cheyenne blinkers
1977 CHEVROLET CHEYENNE
PHIL211
Electrical problem
1977 Chevy Cheyenne V8 Four Wheel Drive Automatic
my front blinkers work my rear flashes hazards
Feb 14, 2010 at 7:54 AM
JDL
  • 16,098 POSTS
Hi, If turn signals at the rear don't work, check voltage and ground at the rear. Right rear turn, voltage wire, dark green. Ground wire is black.
Use a testlite on the green wire, key on, turn signal on, probe the green wire, use chassis ground for testlite, if testlite comes on, there is voltage. If no voltage you backtrack the circuit to the turn signal switch.
Feb 14, 2010 at 8:22 AM
