1973 Chevy Cheyenne, V8, 85,000 miles, 4x4, manual transmission, 1979 Quadrajet carb 4bbl, Edelbrock valve covers and manifold (the large cover under the carb, which I can't remember the name of).
My truck has been sitting for 18 months. At that time the truck started, but not without a few caps of gas poured into the carb. Once it started, it ran just fine. I have reassembled the carburetor that I took apart 18 months ago with a rebuild kit and put that back into the truck. I detached the BAT wire from the Delco-Remy distributor and the fuel line from the carb to see if any fuel was getting up that high, but there was none that I could see.
Why would it take the gas so long to get to the carb, even when it was running? And, once I get that fixed, is there a way to prime the lines in order to getting the truck running again?
Photos attached.
Thank you, Jerry
[img:f292a04fc5]http://www.2carpros.com/forum/automotive_pictures/98519_IMG_0430_1.jpg[/img:f292a04fc5]
[img:f292a04fc5]http://www.2carpros.com/forum/automotive_pictures/98519_IMG_0431_1.jpg[/img:f292a04fc5]
[img:f292a04fc5]http://www.2carpros.com/forum/automotive_pictures/98519_IMG_0432_1.jpg[/img:f292a04fc5]
Photos attached.
Thank you, Jerry
Sep 7, 2007 at 8:25 AM
