1971 Chevy Cheyenne clacking noise in rear end
1971 CHEVROLET CHEYENNE
100,000 MILES • V8 • 2WD • AUTOMATIC
BULLIT03
my truck is making a clacking noise from the diffrential in the rear end, only make the clacking noise when coming to a stop or when let off the throttle. what is causing this noise
Dec 12, 2007 at 1:05 PM
TALON
check your rear u-joint. grab driveshaft and twist back aand forth, see if there is any play
Jan 3, 2008 at 12:58 PM
  • 55,423 POSTS
Yep I agree with TALON, I would check the U joints form what you have described they are the problem which is common.
https://www.2carpros.com/articles/how-to-replace-a-universal-u-joint
Also, check the driveline center support, they go bad as well.
Aug 27, 2024 at 7:40 AM
