1992 Chevy Chevelle
1992 CHEVROLET CHEVELLE
167,000 MILES • 4 CYL • 2WD • AUTOMATIC
KENSCAV
FAILED EMISSIONS TEST
LIMIT READING RESULT
HC ppm 68 142 fail
CO% 0.36 0.53 fail
NO ppm 526 1855 fail
RPM 1734 valid
Dilution 14.2 valid
which parts need to be replaced so it will pass test
Jan 13, 2009 at 12:42 PM
  • 110,244 POSTS
Hi:
I would start by having the O2 sensor tested. Also, is there a check engine light on?
Jan 28, 2009 at 8:49 AM
KENSCAV
no check engine light on but i will replace the o2 sensor. thank you
ps i have since replaced the catylitic converter i will have it checked again could a bad coil pack cause this?
Jan 28, 2009 at 9:20 AM
  • 110,244 POSTS
A weak spark could cause the fuel to not burn properly, so yes. Have the O2 sensor checked prior to replacing. I don't want you to spend money if it's ok.
Jan 28, 2009 at 9:37 AM
