1976 Chevy Chevelle
HUSKYROBERT
Engine Performance problem
1976 Chevy Chevelle V8 Two Wheel Drive Automatic
Installed a new distributer,plugs coil,wires,etc etc. Idles fine,when in PARK runs fine @1500-3000 RPM .However, when driving the truck it coughs,spits barely runs. But as soon as its in PARK it smoths out and is fine. I have tried advancing the timing, fuel / air mixture. Nothing changes HELP! Thanks
Jul 19, 2009 at 9:31 AM
LOUT5369
  • 217 POSTS
You don't say what you have timing at,be sure vac advance is hooked to ported vacuum,maybe advancing too far,check the float in the carb,it's possible engine is leaning out under load.Good Luck,Lou
Jul 22, 2009 at 12:20 AM
