1972 Chevy Chevelle timing chain
DTOOL123
Engine Mechanical problem
1972 Chevy Chevelle V8 Two Wheel Drive Automatic ? miles
I am rebuilding a chevy 427 and would like to know how much timing chain slack is OK, it looks about 1/2". I bought a now sprocket set but it does not match the chain pitch of the crank sprocket and I do not have a puller to replace it.
I would like to keep the old set to avoid the hastle.
Is 1/2" OK?
Feb 5, 2009 at 2:14 PM
  • 75,988 POSTS
You're cutting it short go at your discretion
Feb 5, 2009 at 2:20 PM
BOWTIE BABY
  • 101 POSTS
That seems like a lot of slack to me, I would rent the puller and do it rite. It makes a big difference in performance.
Feb 5, 2009 at 7:21 PM
DTOOL123
Thanks for your reply, I have a puller on the way by noon tomorrow and should have it back in shape within an hour.
Thanks again, I know it was close to the limit, but I have already had a line bore, head bebuild and I already have the new sprocket set. Why stop now?
The motor is a High perf. with square port heads, etc., so I think it is worth the effort.
I am putting this motor into a 1978 Chevy pickup to replace a 350 that spun a bearing. I thought it would be a drop-in, but have run into many issues with this used motor.
Feb 5, 2009 at 8:03 PM
BOWTIE BABY
  • 101 POSTS
No problem, make sure the chain is not stretched. They usually stretch at the same rate the gears wear out. I wish I had a 427, it would sit nice in my camaro. You will love the torque that motor puts out.
Feb 10, 2009 at 9:43 AM
