1972 Chevy Chevelle popping
RICKSS
  • 6 POSTS
Engine Performance problem
1972 Chevy Chevelle V8 Two Wheel Drive Manual
Hi, my 72 Chevelle with a 454 has a popping sound, ( small backfire) from the exhust, seems on passanger side only. When its sitting and idleing and I rev it up it seems ok but when Im driving it im getting this popping?
Any ideas?
Thanks
Jun 30, 2009 at 2:19 AM
BUDDYCRAIGG
  • 2,262 POSTS
backfire is normally a sign of being too lean
Jun 30, 2009 at 3:13 AM
RICKSS
  • 6 POSTS
Hi, its not like a backfire, its more like a popping sound. Have adjusted the carb, cannt get rid of the popping sound
Thanks
Jun 30, 2009 at 3:44 AM
LOUT5369
  • 217 POSTS
First let me say Nice car,Have you tryed adjusting the valves,it sounds like an exhaust valve isn't closing all the way.Put a vacuum gage on it,lets see if vac is steady,if the needle is bouncing you either have a valve too tight or a broken spring.Good Luck,Lou p/s I have a 427 Impala and I love BBCs
Jul 22, 2009 at 12:13 AM
