1972 Chevy Chevelle Fluid leak
PAPPA DUKES
Transmission problem
1972 Chevy Chevelle V8 Automatic
72 turbo 350, is there an overflow if overfilled? Serviced the trans, fluid, filter and modulator valve, deep B & M pan, drained about a gallon out, 6 qts added but barley showing on dip stick. Trail of fluid when driven and small puddle under front left corner of pan (looking from front of car). Was using fluid before, bad mod valve.
Jun 13, 2009 at 1:33 AM
LOUT5369
  • 217 POSTS
I have never been fond of aftermarket pans,but I would clean it off and run it,it's possible shifter shaft seal is leaking,or could be coming from front pump seal,if it's that trans has to come out.Good Luck,Lou
Jul 22, 2009 at 12:26 AM
