1972 Chevy Chevelle crate engine swap
RICKY211
1972 Chevy Chevelle V8 Automatic
I'm doing an engine swap. The oil pan on the 350 crate engine is hitting the cross member on my 72 chevelle. The motor is a Good Wrench replacement motor made between 1980 and 87. the block number is 14101148. It has a really big oil pan on it and I'm assuming a really big crank. ? Any ideas on how to get this motor to fit would be great. Thanks
May 28, 2009 at 4:46 AM
LOUT5369
  • 217 POSTS
All 350s are created equal,get a new pan,1 for a 68-72 chevelle,you should be fine.Good Luck,Lou
Jul 22, 2009 at 12:36 AM
LOUT5369
  • 217 POSTS
I forgot where is the dipstick on the new engine,if it's on the left side you'll be fine,if it's on the right you'll have to get a pan from a speed shop.for that swap
Jul 22, 2009 at 12:38 AM
MICKEY-D
  • 304 POSTS
You will probably need to get an oil pan, and maybe the oil pick up tube for the specific car year.
mickey-d
Dec 2, 2009 at 4:05 PM
