1971 Chevy Chevelle No Power
1971 CHEVROLET CHEVELLE
1 MILES • V8 • 2WD • AUTOMATIC
71MALIBU
Just installed a 350 crate motor and a TH350 trans with all the fluff, e.g.
headers, high rise intake, 750 edelbrock, 50K volt ignition etc. Engine will
rev up like it should to 6K rpms in park and neutral. But in gear it will not
go over 2K rpms - just bogs down and stalls out??? Did check timing and
it advances with rpms. Any ideas??? thanks
Jul 18, 2009 at 3:21 AM
BUDDYCRAIGG
  • 2,262 POSTS
sounds like it's starving for fuel
Jul 19, 2009 at 4:31 PM
LOUT5369
  • 217 POSTS
It sounds to me like the powervalve in the carb is stuck,I would try another carb,Looks like you have a pretty sweet setup there.She should be alotta fun to drive.Plus check your fuel lines make sure there are no kinks,or leaks,a small pin hole in a steel line won't leak but will make the pump suck air. Good Luck,Lou
Jul 22, 2009 at 12:00 AM
