1971 Chevy Chevelle
AUTORON
1971 Chevy Chevelle V8 Two Wheel Drive Automatic
The starter will not disengage. I turn the key to start and it will not disengage, even after removing the key. I have to disconnect the battery. I removed the starter and solenoid and had them tested, replaced them and same thing.
Oct 20, 2009 at 5:50 AM
HMAC300
  • 48,601 POSTS
one of your wires must be hitting the wrong side of the solenoid to cause this. Or your starter wire leading to the ignition switch is still getting uice to possibly being crossed at the wrong place. Another thing to check is make sure you have grounds- body to battery- engine to battery-and body to engine.
Oct 24, 2009 at 6:15 AM
MICKEY-D
  • 304 POSTS
Might be a bad ignition switch, the electrical part. Is it a dash mounted switch, or column? If its on the column, there are two screws that mount the switch. if they get just a little loose,
when you move the key to the crank position,it could cause the starter to keep cranking.
mickey-d
Dec 2, 2009 at 3:02 PM
