1969 Chevy Chevelle Brake Conversion
TOM-329
Brakes problem
1969 Chevy Chevelle V8 Two Wheel Drive 75000 miles
I bleed the front and they bleed good. I bleed the rear and get nothing, and no pedal.
This is a disc brake from a drum and a power booster and master cylinder.
May 9, 2009 at 5:43 AM
LOUT5369
  • 217 POSTS
Sounds like you have alotta air in rear brake lines,try opening the r/rear line and let it gravity bleed,otherwise replace the rubber line from frame to diff it maybe collapsed inside.Good Luck,Lou
Jul 22, 2009 at 12:46 AM
