OIL IS COMING OUT BY THE OIL FILTER REAL FAST WHEN RUNNIG
Jun 1, 2009 at 4:53 AM
LOUT5369
✓Experienced Mechanic
Have you tryed new filter? I would check the oil pressure switch,it's behind the distributer,it could be leakin and running down back of block,some engines have an oil pressure tap above filter,make sure the plug it tight.Let me know,Good Luck,Lou
