1967 Chevy Chevelle spedometer
1967 CHEVROLET CHEVELLE
GOSHAMROCKS
Transmission problem
1967 Chevy Chevelle V8 Two Wheel Drive Manual
We installed new cable it works fine until about 50mph then it buries itself makes alot of noise
Nov 13, 2009 at 1:50 PM
HMAC300
  • 48,601 POSTS
if you just installed a cable an ddidn't check the housing for kinks, or such and didn't lube the cable this could be the cause. Make sure it is tight at both connections as well. Theer could also be abiniding in the cable itself so y ou may have to relace the whole cable assy. Also your speedo may be defective, you can take that to a speedo repair place and they can tell you if there is something wrong with that...
Jan 9, 2010 at 9:39 AM
