1967 Chevy Chevelle power steering
67CHEVYCHEVELLE
Steering problem
1967 Chevy Chevelle V8 Two Wheel Drive Automatic
The power steering turns to the left easily but is difficult to the right. The pressure blows the resivor cap of and blows powersteering fluid all over. When i look at it the resivor is bulbing up.
Apr 2, 2009 at 12:45 PM
DOCFIXIT
  • 18,828 POSTS
Problem in steering gear box
Apr 5, 2009 at 8:02 AM
PENNINGTON32
check your fluid lines . do not just look at them there could be an obstruction inside the line or collapsed inner and not show up as a defect in the outside of the line. remove them and blow air pressure through . start with light pressure then get more . I would recomend blowing it onto a white paper plate this will show any kind of particals that may be in the line. Mike myparts@netzero.net
May 6, 2009 at 12:42 AM
