1967 Chevy Chevelle installing a hurst shift kit
MIKE HELF
Transmission problem
1967 Chevy Chevelle V8 Two Wheel Drive Automatic
i'm putting a hurst shift kit in my '67 chevelle. i need to take out the column shifter. how can i take out the sleeve on the column that holds the stock shift lever and what can i put on the column to replace it.
thanks
Feb 25, 2009 at 1:07 AM
MIKE H R
  • 3,094 POSTS
the shift lever should come out with the two pins holding it in place. If I remember right push the pins in and then you will be able to turn the shift lever a little then remove it. I don't know if there is anything to cover where the shift lever was.
Mar 8, 2009 at 1:44 AM
MICKEY-D
  • 304 POSTS
You need to pull the steering wheel off, remove the signal light switch, and there are I think, three screws holding the sleeve to the column. You will probably have to go to a salvage yard find an old chev like yours with a floor shift and take the sleeve of that car. Or you could get the whole steering column. Good luck with your project.
mickey-d
Dec 2, 2009 at 4:40 PM
