1967 Chevy Chevelle frozen rear brake
250,000 MILES • V8 • 2WD • MANUAL
ROBERTD4861
my old car has been sitting in the garage a very long time. when i tried to tow it one rear wheel was locked up. what steps should i take to fix this problem?
Mar 14, 2009 at 4:37 PM
  • 75,988 POSTS
There's an inspection hole on the backing plate to retract the shoes-there's a special brake tool for it or use two small screwdrivers one to push the starwheel lever inward the other to turn the starwheel
https://images.2carpros.com/forum/automotive_pictures/12900_brandsplace_2041_3325227818_1.jpg
Mar 14, 2009 at 6:55 PM
LOUT5369
  • 217 POSTS
Was the parking brake on? if so back off the cable adjustment under the car and see if that helps.Good Luck,Lou
Jul 22, 2009 at 1:00 AM
