1987 Chevy Celebrity Coolant Leak
TERRY CARMICHAEL
I have an 87 chevy celebrity 2.8 / v6 250,000 on it and i getting coolant in the car on the passenger side floor i was told it was a heater core leak. Now the thermostat is reading hot and the rad is cool to the touch. I have been filling it with coolant regulary and the thermostat has never read hot. So, is it my my heater core thermostat or is there more than one problem?
I was also told it could be a head gasket. is ther a way to check for these problems or should i just take it to a machanic?
i only paid $500 for the car should i scrape it?
Oct 30, 2007 at 10:39 AM
BMRFIXIT
  • 19,053 POSTS
[quote:100bfc72a6="terry carmichael"]I have an 87 chevy celebrity 2.8 / v6 250,000 on it and i getting coolant in the car on the passenger side floor i was told it was a heater core leak. Now the thermostat is reading hot and the rad is cool to the touch. I have been filling it with coolant regulary and the thermostat has never read hot. So, is it my my heater core thermostat or is there more than one problem?
i only paid $500 for the car should i scrape it?[/quote:100bfc72a6]
before u scrape it
have it checked
u need the heater core
its a small like radiator under the dash in the
HVAC box that heat the air inside the car
as for the head gasket you need to have it checked
sure they can test the head gasket its EZ and quick
good luck
Oct 30, 2007 at 12:30 PM
Suggested Repair
Do not scrap the car yet. Have the heater core replaced and have a quick head-gasket test performed.
Conversation Summary
The owner of a 1987 Chevrolet Celebrity with a 2.8 V6 reports coolant on the passenger floor, a hot temperature gauge with a cool radiator, and regular coolant loss. A heater core or head gasket was suggested. The expert advises having it checked rather than scrapping it: the heater core under the dash is needed, and a head-gasket test is easy and quick.
