2000 Chevy cavalier
ANTHONY C.
Electrical problem
2000 Chevy Celebrity 4 cyl Automatic 122000 miles
car starts and runs but will stop running, it just dies, it wil after several minutes start back up. it may run for a while then again it may run only for a few minutes
Aug 12, 2009 at 6:44 AM
JDL
  • 16,098 POSTS
Hello, can you double-check the model year for me? If the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the plugs and injector pulse. With TBI you should be able to see injector spray? If no spark or injector spray, maybe a problem with rpm signal? Any codes?
Aug 12, 2009 at 7:02 AM
ANTHONY C.
[quote:8dcd128843="Anthony C."]Electrical problem
2000 Chevy cavalier 4 cyl Automatic 122000 miles
car starts and runs but will stop running, it just dies, it wil after several minutes start back up. it may run for a while then again it may run only for a few minutes[/quote:8dcd128843] car runs and drives good untill it dies, several minutes to an hour till you can start it a again
Aug 12, 2009 at 7:44 AM
